Главная Новости ПулКОН РСДБ Обсерватории Публикации About us Контакт
Russian Academy of Sciences
Central Astronomical Observatory at Pulkovo
SIXTH US/RUSSIAN
SPACE SURVEILLANCE WORKSHOP
August 22-26, 2005
Proceedings
Edited by P. Kenneth Seidelmann and Victor K. Abalakin
St. Petersburg, 2005
ON OBSERVATIONS OF SATELLITES AT THE HISSAR OBSERVATORY
М. I. Gulyamov
The Academy of Sciences Institute of Astrophysics, Republic of Tajikistan
Abstract. The present paper deals with positional observations made by use of the High-Precision Astronomical Camera (HPAC, Высокоточная астрономическая установка, ВАУ) at the Hissar Astronomical Observatory in 1989-2000 which were used to compile the catalogue of the precise positions of geostationary objects (GO). The mean square errors do not exceed 1.5-2 arcsec. The longitude of the Observatory is 69 degrees to the East, allowing to make observations of many uncontrollable GO, and to use these data to test the theory of motion of the librating GO. Preliminary elements of their orbits are determined and the catalogue of GO orbits is compiled based on the Hissar version of the GO position catalogue. The catalogue contains elements of orbits of all identified active and passive geostationary satellites.
The problem of construction of the theory of geostationary satellite motions is an urgent task. Positional photographic observations of these objects during a long time-span [1, 2, 3] may represent the valuable material for its solution.
Many geostationary objects (GO) are accessible to optical observation instruments with which the observatories participating in the joint program of the control of the cosmic space in the geostationary region are equipped.
Since 1975 surveillance observations are regularly carried out by use of the High- precision astronomical camera (HPAC) at the Hissar Astronomical Observatory (HissAO) of the Institute of Astrophysics of the Tajikistan Academy of Sciences. These observations are closely connected with applied works and represent valuable material for the decision of a number of fundamental and applied tasks in the fields of Astronomy, Geodesy, Geophysics, and Celestial Mechanics.
THE HIGH-PRECISION ASTRONOMICAL CAMERA
This camera is supplied with the “Astrodar” objective lens with an aperture of 500 mm, a focal length of 700 mm, and an effective relative aperture of 1:1.8. The effective diameter of the entry pupil is 390 mm, the basic mirror diameter is 1070 mm, and the camera field of view is of 5 degrees by 30 degrees. The observations are made on a photographic film 70 mm wide, which is stretched over the spherical focal surface of the curvature radius of 700 mm. The images of the stars and space objects show no distortions on the entire frame, because of the well-designed objective lens [4].
The telescope is automatically guided and operated from the main control panel. The camera carries out the photographic observations of artificial satellites in a wide range of angular speeds from 0 to 6000 arcsec per second, and has significant permeable force. Now it is the largest follow-up satellite camera.
The camera is equipped with a leaf shutter, which operates automatically under control of the device described in [5]. The device assigns a necessary sequence of shutter operations and determines exact exposure times. The registration of shutter opening-closing time- moments is controlled by a printing chronograph. The complete set of camera service equipment contains the СЕВ (the Universal Time Service) hardware. Two quartz generators are used at the observation station as the exact time keepers, and the «Волна - K» radio receives the exact time signals. The system is capable of registering the observation time to an accuracy of ± 0.0001 sec. The experience of the everyday work has shown that the camera is especially convenient for observations of high-orbital satellites. The determined celestial object coordinates are accurate to 1.5 arcsec.
The longitude of the HissAO is 69 degrees to the East, the Observatory being close to the meridian passing through one of the libration points (75 degrees), which presents a certain convenience in carrying out the GO position observations, and in searching for passive objects moving near the libration point in the geostationary region. The geographical location and the instrumentation used permit observing objects in geostationary orbits in East longitudes ranging from 20 to 120 degrees, and practically all objects up to the stellar magnitude of 14.5.
The geostationary region is repeatedly photographed during an observation night, which allows determining exact positions of objects with respect to the reference stars, and the mathematical treatment of observations of the objects related to various sections of their orbits. The observations of GO objects are usually carried out in the best conditions of their visibility, i.e. near their maximum phase.
The negatives are processed by use of the hardware-software complex “Astrolog”, which allows obtaining the operative coordinate information from photographic observations [6]. The measuring pad of the “Аscoremat” coordinate-measuring machine is connected by means of an adapter to a РС. The measurement program is organized and adapted to read off the information from the rulers of the measuring device, and to record it on the hard disk of the РС. It also carries out the correctness check of the incoming information.
The programs for identification of reference stars on negatives, obtained by the High- precision astronomical camera, and for their reduction are based on known algorithms [7]. For identification of the negatives, an observation date (DATE), the time-moment (UT), and the circle readouts of the camera only are needed. The compiled programs provide a complete identification, if the correct initial information is introduced. The Position and Proper Motion Star Catalogue (the PPM Catalogue) is used as a reference catalogue, allowing to obtain precise observation results for the equinox epochs of 1950.0 and 2000.0. The SAO catalogue used earlier by the negative processing has provided an accuracy of 0.85 arcsec. When applying the PPM catalogue, the errors related to the weight unit have decreased by 0.3 arcsec on average [8].
The hardware support routines are written in the Assembler, the other ones in the Turbo Pascal.
68 surveillance observations of the geostationary region for the 1989 – 2000 period are carried out by the High-precision astronomical camera. The surveillance results are given in Table 1. The precise position catalogue is generated [9] as a result of the mathematical treatment of all the surveillance observations. It contains 11,000 precise positions of 2,971 GOs. As an example, a fragment of the precise position catalogue is given in Table 2. In the table are given as follows: the observation date, a number of geostationary objects, the equatorial topocentric coordinates (α, δ) of a GO referred to the standard epoch of 1950.0 and the universal time (UT).
The satellite identifications at the observation station were carried out within the limits of one surveillance session. During processing the identifications were performed visually on the negatives, accounting for the satellite movement, and also by use of the sorting software, which enables watching on the РС screen the apparent movement of an GO during the observation, and to eliminate gross blunders using the velocity diagram.
The accuracy estimation of the position observation results was performed using the residual mean square deviations for the reduction formulas. The mean square deviations of the precise positions in the catalogue, calculated for a majority of GOs, do not exceed ± 2 arcsec; they equal ± 5 arcsec for only a rather small quantity.
On the basis of the obtained precise position catalogue, the preliminary version of the Hissar GO catalogue is compiled, including the active geostationary satellites and the passive ones which move in the libration mode. This catalogue is very important for the control of the large number of the economic satellites, and can be used for the solution of problems concerned with the ecology of the near-Earth cosmic space.
The elements of the preliminary orbits were computed by using the programs compiled in the Laboratory of Celestial Mechanics and Stellar Dynamics at the Central (Pulkovo) Astronomical Observatory of the Russian Academy of Sciences, and kindly granted to us by the scientific workers Drs. A. S. Sochilina and K. V. Grigoriev, within the framework of the joint scientific and technical cooperation between our observatories.
The elements of the orbits were determined in the coordinate systems referred to the geoequator and Laplace planes [10].
The identification of objects was performed on the basis of the lists of geostationary objects (LOG) distributed in 1992-1995 by the European Space Operative Centre (ESOC) [11]. The use of these lists has allowed identifying 91 satellites (55 active satellites and 36 passive ones) internationally designated (by the COSPAR designations).
As a basis for a GO identification the following elements of the calculated orbits [12] were taken: i, the inclination of an orbit, Ω, the longitude of its ascending node and λ, the longitude in the orbit:
λ = M + ω + Ω - S
where M is the mean anomaly, ω, the argument of the perigee, S, the Greenwich Sidereal Time.
Because of the small eccentricity the parameters e and ω are determined unreliably, and, therefore, these parameters were not used for the identifications.
As an example, fragments of the identification results from the Hissar catalogue of orbits are given in tables; for the active geostationary satellites in Table 3 and for passive ones in Table 4. The elements of the geostationary satellite orbits are given in the following order: T(MJD), the modified Julian date; i, the orbit inclination; Ω, the longitude of the ascending node of the orbit referred to the equator plane; iL, the orbit inclination; ΩL, the longitude of the of the orbit ascending node referred to the Laplace plane; λ, the longitude in the orbit.
The version of the Hissar catalogue of orbits is the result of an intensive program of optical observations, which have been made by use of the High-precision astronomical camera in 1989-2000, containing the preliminary orbits of all identified objects, and is the basis of the list of GOs monitored at the HissAO in the geostationary area.
The catalogue allows detecting new satellites and those which were launched at earlier times. It will be useful for those observation stations which overlap in the longitudes observable with the HissAO, both for comparison of the observation results, and for identification of individual space objects.
  1. Георгиев Н. И., Масевич А. Г., Кленицкий Б. М., Татевян С. В. В кн.: Ис-пользование оптических наблюдений искусственных спутников Земли для геодезии. София: Издательство Болгарской АН, 1979, 275 с.
  2. Рыхлова Л. В. Использование наблюдений ИСЗ для решения задач геоди-намики. Наблюдения ИСЗ, М., 1974, № 13, с. 194-218.
  3. Сочилина А. С. Об использовании геостационарных спутников для определения параметров геопотенциала. Наблюдения ИСЗ. Прага, Астросовет АН СССР, 1984, № 23, с. 211-231.
  4. Масевич А. Г., Лозинский А. М. Новые советские камеры для фотонаблюдений искусственных небесных тел. Вестник АН СССР, 1970, № 2, с. 38-44.
  5. Бирюков А. Н. Прибор для автоматического управления затвором камеры ВАУ при фотографировании геостационарных ИСЗ. Научные информации Астрономического совета АН СССР, № 58, 1986, с. 81-86.
  6. Голод В., Денисов А., Матвеев Н. Н. Аппаратно-программный комплекс для измерений и обработки координатной информации. Тезисы доклада в сборнике «Организация программ наблюдений высокоорбитальных спутников Земли и небесных тел Солнечной системы». Санкт-Петербург, 1992 г.
  7. Матвеев Н. Н. Об автоматическом отождествлении опорных звезд на астронегативах. Научные информации Астрономического Совета АН СССР, 1987, № 62.
  8. Матвеев Н. Н. О точности каталогов PPM и SAO. Астрономический циркуляр, 1992, № 1553.
  9. Гулямов М. И., Литвинов С. П., Масуми Ф. Н., Матвеев Н. Н., Мулло-Абдолов А. Ш., Наимов О., Юлчиев А. О. Результаты позиционных фотографических наблюдений геостационарных спутников на камере ВАУ. Реферативный сборник непубликуемых работ, выпуск 01 2004 г., депонент НПИЦ РТ № 30 (1651), 118 стр.
  10. Гаязов И. С., Сочилина А. С. 1986. О выборе координатной системы для исследования движения высокоорбитальных спутников - Бюлл.ИТА, № 9(172), с.481-485.
  11. Janin G. LOG of objects near the geostationary ring. Issues Nos. 6 - 15, ESOC, 1992 - 1993.
  12. Григорьев К. В., Гулямов М. И., Сочилина А. С. О методах отождествления неуправляемых геостационарных спутников. Наблюдения ИНТ, 1994, № 88, с. 57.
Table 1. THE SESSIONS OF SURVEILLANCE OF THE GEOSTATIONARY REGION IN 1989-2000
HissАО АS RТ
№ date of observation quantity of the satellites with number of observations all objects
1 2 3 4 5 6 7 8 9 *
1 2 3 4
1 04.03.1989 0 0 14 5 2 2 1 1 0 0 25
2 05.04.1989 0 0 10 9 1 4 0 1 1 0 26
3 10.05.1989 0 2 21 5 9 3 0 0 0 0 40
4 11.05.1989 0 1 8 7 2 0 0 0 0 0 18
5 12.05.1989 0 0 0 2 0 0 0 0 0 0 2
6 26.06.1989 0 2 26 1 1 2 0 0 0 0 32
7 04.08.1989 0 1 35 11 2 3 0 0 0 0 52
8 27.09.1989 0 3 25 10 9 3 1 0 0 0 51
9 02.10.1989 0 0 0 0 0 0 0 0 1 0 1
10 29.11.1989 0 3 50 3 3 2 0 0 0 0 61
11 20.02.1990 0 0 35 1 2 1 0 0 0 0 39
12 31.05.1990 0 0 22 21 1 1 0 0 0 0 45
13 27.06.1990 0 0 25 11 0 0 0 0 0 0 36
14 24.07.1990 0 0 10 23 1 0 1 0 0 0 35
15 20.08.1990 0 0 18 20 3 0 0 0 0 0 41
16 25.10.1990 0 0 20 36 4 1 0 0 0 0 61
17 14.01.1991 0 0 6 3 0 0 0 0 0 0 9
18 15.02.1991 0 2 49 5 1 5 0 0 0 0 62
19 16.05.1991 0 0 15 29 0 0 0 0 0 0 44
20 12.08.1991 0 0 23 5 1 0 0 0 0 0 29
21 03.09.1991 0 0 0 0 0 0 0 1 0 0 1
22 05.09.1991 0 0 0 0 0 0 0 0 0 1 1
23 03.10.1991 0 8 52 8 0 0 0 0 0 0 68
24 07.12.1991 0 0 1 0 1 0 3 4 1 0 10
25 07.02.1992 0 0 25 48 3 0 0 0 0 0 76
26 05.03.1992 0 0 9 0 0 0 0 0 0 0 9
27 03.07.1992 0 2 8 15 12 4 3 0 0 0 44
28 04.07.1992 0 1 11 11 7 7 2 0 0 0 39
29 05.07.1992 0 1 1 5 9 8 8 3 3 0 38
30 03.08.1992 0 2 57 6 12 1 1 0 0 0 79
31 20.10.1992 0 1 20 15 1 0 1 0 0 0 38
32 22.10.1992 0 2 54 29 6 1 0 0 0 0 92
33 23.10.1992 0 1 25 11 2 0 0 0 0 0 39
34 26.10.1992 0 0 22 49 3 0 0 0 0 0 74
35 27.10.1992 0 3 29 32 5 0 0 0 0 0 69
36 31.10.1992 0 1 64 7 3 0 0 0 0 0 75
37 23.11.1992 0 0 0 1 0 1 0 1 0 1 4
38 20.02.1993 0 1 6 22 0 0 1 0 0 0 30
39 21.06.1993 0 0 4 9 1 0 0 0 0 0 14
40 22.08.1993 0 0 11 14 3 1 1 0 0 0 30
41 19.11.1993 0 2 48 0 1 0 0 0 0 0 51
42 15.01.1994 0 0 25 29 50 6 3 0 0 3 116
43 18.03.1994 0 6 23 9 0 0 0 0 0 0 38
44 15.06.1994 0 1 59 15 0 4 1 0 0 0 80
45 08.10.1994 0 4 43 16 3 0 0 0 0 0 66
46 29.01.1995 0 2 26 42 8 6 0 0 0 0 84
47 30.01.1995 0 0 62 13 5 1 0 0 0 0 81
48 30.03.1995 0 0 9 9 0 0 0 0 0 0 18
49 06.05.1995 0 1 11 21 0 0 0 0 0 0 33
50 30.05.1995 0 0 2 0 0 0 0 0 0 1 3
51 04.06.1995 0 2 25 57 3 0 0 0 0 0 87
52 30.07.1995 0 0 4 55 8 0 1 0 0 0 68
53 18.10.1995 0 0 0 1 1 0 1 0 0 0 3
54 19.10.1995 0 0 1 14 30 2 2 0 0 0 49
55 25.05.1996 0 1 15 30 14 4 0 0 0 0 64
56 21.06.1996 0 1 10 18 0 0 3 0 0 0 32
57 20.07.1996 0 1 25 23 2 4 2 0 0 0 57
58 15.06.1998 0 1 13 7 0 0 0 0 0 0 21
59 29.06.1998 0 0 1 7 17 0 0 0 0 0 25
60 24.07.1998 0 3 5 5 0 0 0 0 0 0 13
61 26.07.1998 0 0 15 34 11 1 0 1 0 0 61
62 21.08.1998 0 1 19 6 0 0 0 0 0 0 26
63 17.10.1998 0 0 27 2 6 0 0 0 0 0 35
64 18.06.1999 0 0 34 59 1 0 0 0 0 0 94
65 15.07.1999 0 3 48 36 1 0 0 0 0 0 88
66 16.07.1999 0 5 2 0 0 0 0 0 0 0 7
67 15.08.1999 0 0 12 68 3 2 0 0 0 0 85
68 05.06.2000 0 1 42 1 1 1 0 0 0 0 46
quantity of the
satellites
0 72 1417 1066 275 81 36 12 6 6 2971
quantity of the
precise
positions
0 144 4251 4264 1375 486 252 96 54 78 11 000
The note: The figures in the last column of table 1 mean:
72 Geostationary Objects (GO) have up to 2 precise positions (p.p.), 1417 GO - 3 p.p., 1066
GO - 4 p.p.,
275 GO - 5 p.p., 81 GO - 6 p.p., 36 GO - 7 p.p., 12 GO - 8 p.p., 6 GO - 9 p.p.
6 GO -10 and more p.p.
2971 - total quantity of the geostationary objects
11 000 - total quantity of the precise positions
Table 2. CATALOGUE OF THE EQUATORIAL TOPOCENTRIC COORDINATES OF GEOSTATIONARY OBJECTS
HissАО АS RТ
date № GO UT α1950 δ1950 date № GO UT α1950 δ1950
14.03.1989 h m s h m s ° ' '' h m s h m s ° ' ''
1 16 21 12.85 12 04 25.76 -3 48 50.36 12 16 08 13.07 9 30 22.95 -5 56 48.71
18 54 13.00 14 37 51.22 -4 14 10.86 17 16 57.94 10 39 20.59 -5 58 34.11
20 11 03.06 15 54 52.51 -4 42 13.53 19 43 16.95 13 06 12.54 -6 01 56.50
2 16 08 13.07 10 48 33.69 -5 36 06.51 21 03 08.01 14 26 21.46 -6 03 11.95
17 16 57.94 11 57 28.69 -5 35 18.84 21 55 17.77 15 18 43.77 -6 03 41.36
21 03 08.01 15 44 12.54 -5 41 05.00 13 16 08 13.07 9 22 57.92 -5 50 58.53
21 55 17.77 16 36 30.62 -5 43 51.52 17 16 57.94 10 31 50.22 -5 49 01.09
3 16 08 13.07 10 38 20.41 -6 03 43.95 19 43 16.95 12 58 26.22 -5 47 54.53
16 21 12.85 10 51 22.04 -6 03 47.20 22 26 37.00 15 42 05.29 -5 51 39.65
17 16 57.94 11 47 15.37 -6 03 19.13 14 16 08 13.07 9 14 41.32 -6 43 43.48
18 54 13.00 13 24 44.72 -6 00 49.77 17 16 57.94 10 23 25.01 -5 38 17.30
19 43 16.95 14 13 56.61 -5 58 56.46 19 43 16.95 12 49 54.36 -3 31 51.94
20 11 03.06 14 41 46.08 -5 57 29.13 21 05 42.96 14 12 35.96 -2 43 47.08
21 03 08.01 15 33 58.88 -5 54 48.41 21 08 42.92 14 15 36.81 -2 42 28.46
21 55 17.77 16 26 16.83 -5 51 53.25 15 16 08 13.07 9 07 46.46 -5 10 06.05
4 16 08 13.07 10 35 24.00 -5 41 43.31 17 16 57.94 10 16 40.27 -5 00 57.44
16 21 12.85 10 48 25.19 -5 41 23.56 21 03 08.01 14 03 18.50 -5 09 19.32
17 16 57.94 11 44 16.30 -5 40 15.18 21 13 03.00 14 13 14.61 -5 10 58.65
18 54 13.00 13 21 41.95 -5 39 49.58 21 55 17.77 14 55 34.72 -5 19 06.61
19 43 16.95 14 10 52.09 -5 40 27.58 22 26 37.00 15 26 58.59 -5 26 00.36
20 11 03.06 14 38 40.87 -5 40 55.34 16 21 08 42.92 13 41 10.22 -1 48 13.33
21 03 08.01 15 30 52.31 -5 42 16.83 22 10 02.87 14 43 21.60 -2 50 20.73
5 16 08 13.07 10 27 03.33 -5 40 56.90 22 26 37.00 15 00 08.16 -3 09 51.88
18 54 13.00 13 13 26.74 -5 40 23.43 17 21 08 42.92 13 23 30.98 -3 07 22.77
19 43 16.95 14 02 38.46 -5 41 26.69 21 13 03.00 13 27 51.86 -3 09 14.88
20 11 03.06 14 30 27.33 -5 42 12.58 22 10 02.87 14 25 00.36 -3 40 17.78
21 03 08.01 15 22 39.67 -5 44 03.93 22 26 37.00 14 41 37.36 -3 51 07.16
21 55 17.77 16 14 56.70 -5 46 21.71 18 21 08 42.92 13 22 13.64 -2 33 14.79
6 16 08 13.07 10 22 46.43 -6 58 51.26 22 10 02.87 14 23 47.24 -3 14 19.07
19 43 16.95 14 01 14.53 -6 54 27.91 22 26 37.00 14 40 25.11 -3 27 37.68
21 03 08.01 15 22 29.80 -6 38 23.36 19 21 23 33.00 13 03 35.30 -0 01 33.40
7 19 47 02.92 14 01 16.91 -2 37 54.00 22 10 02.87 13 50 16.65 -0 58 08.60
21 05 42.96 15 19 57.20 -3 37 05.20 22 43 22.84 14 23 40.31 -1 45 45.37
21 55 17.77 16 09 28.53 -4 22 59.13 20 18 06 02.94 9 41 22.77 -2 15 09.57
8 16 08 13.07 10 04 18.26 -5 14 55.51 21 23 33.00 12 59 47.45 -1 17 58.18
19 43 16.95 13 39 52.71 -5 11 58.51 22 43 22.84 14 19 59.77 -1 54 47.83
21 03 08.01 14 59 54.43 -5 20 41.27 21 21 13 03.00 12 42 04.95 -4 15 24.95
21 55 17.77 15 52 12.12 -5 28 47.28 22 26 37.00 13 55 51.67 -4 10 34.12
9 19 43 16.95 13 38 22.40 -3 12 19.54 22 38 02.96 14 07 18.78 -4 10 52.02
21 52 22.86 15 46 49.21 -7 37 04.12 22 21 13 03.00 12 38 18.52 -3 57 10.90
21 55 17.77 15 49 43.42 -7 43 04.84 22 26 37.00 13 52 03.72 -4 17 45.75
10 16 08 13.07 9 46 07.22 -6 54 45.37 22 38 02.96 14 03 30.41 -4 22 01.80
17 16 57.94 10 55 02.62 -7 02 35.80 23 18 06 02.94 9 26 57.02 -1 38 09.51
19 43 16.95 13 21 44.45 -6 59 22.07 22 10 02.87 13 32 13.15 -1 58 36.43
21 55 17.77 15 34 01.85 -6 34 57.28 22 43 22.84 14 05 38.98 -2 25 37.04
11 16 08 13.07 9 44 41.03 -4 49 23.49 24 21 18 32.95 11 30 10.50 -7 18 22.80
19 43 16.95 13 20 07.27 -4 44 31.61 22 32 42.83 12 44 33.40 -7 19 08.05
21 55 17.77 15 32 19.14 -5 12 59.48 22 38 02.96 12 49 54.39 -7 18 55.31
25 15 33 02.81 3 16 16.05 -5 54 36.91 22 51 31.46 17 11 35.72 -6 08 33.77
17 50 13.02 5 32 54.47 -5 47 40.68 23 10 39.46 17 30 46.12 -6 09 31.67
5.04.1989 20 01 22.98 7 43 33.57 -5 40 20.04 23 12 20.46 17 32 27.49 -6 09 37.20
26 19 22 38.47 15 10 02.81 -6 36 51.83 36 19 48 08.47 14 06 06.09 -6 45 25.30
19 48 08.47 15 35 35.78 -6 31 04.82 20 48 40.47 15 06 50.69 -6 39 29.13
20 23 58.47 16 11 29.95 -6 22 15.06 21 43 48.46 16 02 10.16 -6 31 49.49
20 48 40.47 16 36 14.69 -6 15 44.61 21 45 28.47 16 03 50.44 -6 31 35.42
21 35 58.47 17 23 38.14 -6 02 46.31 22 01 19.47 16 19 44.88 -6 29 02.27
22 01 19.47 17 49 02.11 -5 55 40.64 22 51 31.46 17 10 07.08 -6 20 10.68
27 19 22 38.47 15 08 23.41 -5 04 10.46 23 10 39.46 17 29 18.95 -6 16 34.55
19 48 08.47 15 33 56.98 -5 11 35.31 23 12 20.46 17 31 00.27 -6 16 14.05
20 23 58.47 16 09 51.94 -5 22 48.79 23 23 01.53 17 41 43.46 -6 14 11.41
20 48 40.47 16 34 37.29 -5 31 03.46 37 19 46 30.47 14 03 49.48 -0 50 23.78
21 35 58.47 17 22 01.79 -5 47 36.96 20 47 00.47 15 04 32.41 -1 59 38.86
22 01 19.47 17 47 26.36 -5 56 39.99 21 45 28.47 16 03 02.95 -3 22 37.87
28 19 22 38.47 15 07 58.84 -6 08 56.57 22 01 19.47 16 18 53.36 -3 46 58.73
19 48 08.47 15 33 30.78 -6 07 53.65 38 21 43 48.46 15 42 17.02 -3 59 12.10
20 23 58.47 16 09 23.95 -6 06 09.90 21 45 28.47 15 43 56.61 -4 02 25.01
20 48 40.47 16 34 08.12 -6 04 47.74 23 23 01.53 17 21 08.94 -7 07 13.65
21 35 58.47 17 21 31.16 -6 01 59.87 39 21 43 48.46 15 37 05.10 -5 55 00.08
22 01 19.47 17 46 55.26 -6 00 21.06 21 45 28.47 15 38 45.35 -5 55 04.43
29 19 22 38.47 15 05 07.65 -5 30 39.51 22 51 31.46 16 44 58.53 -5 57 58.08
20 23 58.47 16 06 37.25 -5 39 39.93 23 23 01.53 17 16 33.63 -5 59 30.79
20 48 40.47 16 31 23.15 -5 43 41.02 40 21 43 48.46 15 32 00.42 -5 01 44.80
21 35 58.47 17 18 48.91 -5 51 47.56 21 45 28.47 15 33 40.63 -5 02 35.76
30 19 22 38.47 14 51 46.17 -6 00 31.01 22 51 31.46 16 39 53.19 -5 38 38.02
19 48 08.47 15 17 21.88 -6 00 59.02 23 23 01.53 17 11 27.80 -5 56 46.75
20 23 58.47 15 53 19.89 -6 01 35.21 41 21 45 28.47 15 31 43.89 -4 32 46.04
20 48 40.47 16 18 07.14 -6 01 55.83 22 51 31.46 16 38 13.54 -5 29 00.69
21 35 58.47 17 05 34.89 -6 02 33.76 23 23 01.53 17 09 56.86 -5 57 02.30
23 12 20.46 18 42 15.14 -6 03 12.29 42 21 43 48.46 15 17 14.81 -4 09 57.84
31 19 48 08.47 15 08 48.68 -5 47 54.34 21 45 28.47 15 18 54.99 -4 11 21.57
20 48 40.47 16 09 28.31 -5 50 54.54 22 51 31.46 16 25 00.52 -5 12 42.99
22 01 19.47 17 22 17.41 -5 55 08.72 23 23 01.53 16 56 31.20 -5 43 36.96
23 10 39.46 18 31 48.44 -5 59 40.39 43 21 45 28.47 15 18 22.52 -4 54 15.86
23 12 20.46 18 33 29.74 -5 59 45.78 22 51 31.46 16 24 34.19 -5 30 59.35
32 19 46 30.47 15 00 04.11 -2 24 08.03 23 23 01.53 16 56 08.47 -5 49 47.29
20 47 00.47 16 00 51.65 -2 17 34.48 44 21 43 48.46 15 16 08.27 -4 16 46.70
21 59 25.47 17 13 37.54 -2 30 09.47 21 45 28.47 15 17 48.74 -4 17 06.08
22 57 29.46 18 11 56.70 -2 55 26.95 22 51 31.46 16 24 04.57 -4 34 49.50
33 19 48 08.47 14 32 13.75 -4 37 40.47 23 23 01.53 16 55 40.12 -4 45 59.72
20 48 40.47 15 32 53.66 -4 43 23.46 45 21 43 48.46 15 01 00.47 -5 56 43.42
22 01 19.47 16 45 42.58 -4 57 22.87 22 51 31.46 16 08 50.75 -5 58 13.43
34 19 46 30.47 14 17 31.00 -3 07 03.96 23 23 01.53 16 40 24.67 -5 59 06.18
19 48 08.47 14 19 09.41 -3 08 15.09 46 21 43 48.46 14 46 53.84 -5 55 56.82
20 48 40.47 15 19 51.36 -4 00 39.42 21 45 28.47 14 48 33.93 -5 55 59.27
35 19 48 08.47 14 07 55.21 -5 58 24.54 22 51 31.46 15 54 44.25 -5 57 23.74
20 48 40.47 15 08 31.94 -6 01 46.84 23 23 01.53 16 26 17.85 -5 58 16.38
21 43 48.46 16 03 44.98 -6 04 55.70 47 19 03 11.46 11 52 52.29 -5 57 30.47
21 45 28.47 16 05 25.19 -6 05 01.93 21 43 48.46 14 33 50.03 -5 55 25.42
22 01 19.47 16 21 17.93 -6 05 53.82 21 45 28.47 14 35 30.19 -5 55 24.41
Table 3. The result of identification of an active geostationary satellite
NumberInternational numberNameCountryType
341983 105A“Intelsat 5 f-7”USA-ITActive
T(MJD) i iL Ω ΩL λ
47622d.952448 0°.084 7°.302 251°.171 180°.629 66°.007
47658.769635 0.118 7.277 268.906 180.935 66.075
47659.853871 0.116 7.277 269.124 180.915 66.050
47704.807922 0.026 7.254 41.156 179.864 65.993
47743.839172 0.023 7.276 95.051 179.816 65.921
47797.706325 0.024 7.298 179.540 179.998 65.979
47860.836673 0.080 7.262 279.143 180.625 65.973
47943.838571 0.023 7.287 236.955 180.154 66.033
48043.860353 0.044 7.263 284.336 180.335 65.962
48070.859427 0.049 7.251 61.656 179.661 65.976
48097.838224 0.088 7.260 80.464 179.316 65.977
48124.827668 0.154 7.273 88.935 178.784 66.025
48393.756001 0.786 7.163 78.834 173.800 56.940
48481.773941 1.036 7.159 79.571 171.793 56.876
48533.866534 1.136 7.153 79.421 170.997 56.874
48660.810284 1.469 7.100 77.443 168.319 56.914
48807.847205 1.820 7.020 74.826 165.472 56.943
48808.846059 1.822 7.021 74.851 165.456 56.955
48809.848224 1.824 7.020 74.839 165.445 56.969
49039.846534 1.893 7.027 75.056 164.877 56.881
50010.861684 2.040 7.002 74.299 163.670 56.824
50219.889867 2.048 6.990 73.975 163.607 56.845
50606.891906 2.051 6.988 73.911 163.580 56.856
51105.891904 2.066 6.985 73.844 163.458 56.828
51375.805678 2.767 6.894 71.147 157.631 56.757
51701.845307 2.946 6.829 69.627 156.096 56.783
Table 4. The result of identification of a passive geostationary satellite
171983 100A“Statsionar-Ekran”- 11USSRLibr
T(MJD) i iL Ω ΩL λ
47704d.752832 4°.910 7°.546 73°.779 141°.256 86°.044
47860.805607 5.016 7.575 73.624 140.476 77.843
48043.742436 5.120 7.566 73.017 139.588 66.131
48097.836673 5.290 7.527 71.739 138.050 54.698
48190.860353 5.752 7.524 69.557 134.179 52.531
48660.857691 5.841 7.544 69.365 133.504 56.431
48916.811511 5.901 7.551 69.151 133.017 61.175
49160.739775 6.091 7.514 67.868 131.266 80.859
49519.769636 6.909 7.485 63.781 124.069 78.809
50009.808548 7.224 7.474 62.202 121.227 53.918
50256.849312 7.638 7.447 60.002 117.365 52.392
50606.822182 7.784 7.403 58.917 115.803 65.730
51046.780747 7.802 7.412 58.917 115.689 66.124
51375.825237 7.812 7.397 58.731 115.516 68.031
Размещен 20 декабря 2006.
