A CONCEPT OF THE PURPOSEFUL RESEARCH OF THE DYNAMICS OF MAN-MADE CONDITIONS ON GEOSTATIONARY ORBITS (GEO) DURING THE SPACECRAFT DEVELOPMENTA.F. Klishin, G.D. GotovtsevLavochkin Association, Russia
1. INTRODUCTIONThere exists the environmental problem caused by the cosmic space clogging up by the
working spacecraft (S/C), the thrown-away upper stages (U/S), and their fragments generated
by the S/C and U/S destruction, because of explosions or as a result of collisions among
themselves. This problem is an actual one and is concerned with the endangering influence on
the spacecraft functioning, because of probable negative consequences of the space debris (the
man-made formations).
Features of the man-made formations and the condition status in the geostationary orbit
(GEO) region represent the self-dependent, complex and complicated multilateral problem for
the following reasons:
The last reason testifies that the natural «process of crushing», i.e. the independent fast
increase of man-made objects due to the formation of new small man-made objects, has
begun and exists. Now this process is an uncontrollable one and also represents the ever-
growing main threat for the existence of the new spacecraft, launched with various purposes
into this region. While the amount of large man-made objects is measured in hundreds, the
small objects are counted by thousands and tens of thousands.
The international community is aiming at development of comprehensive and effective
standards and regulations for the rate reduction of the GEO choking-up by the man-made
formations, but those did not yield the desirable results yet. It seems that the boundary, when
it was still possible to specify and develop the measures for efficient control of this process by
technical means and with little material inputs, has imperceptibly already been crossed. It is
expected that in the future the development of the serious, obligatory decisions for execution
of expensive actions is necessary to overcome the consequences of the spontaneous
developing of the GEO region and to decrease the SMO formation rate. Currently, in view of
the circumstances mentioned, it is necessary to develop and improve methods to control the
man-made conditions in the GEO, including the onboard means for surveillance and
registration of the meteoroids and man-made objects, and also to eliminate by all available
means, whenever it is possible, the negative ecological consequences of the space activities
proceeding in this space region.
It is known, that today there are ~ 1000 large catalogued space objects (approximately
85 % of them are man-made) with the sizes > 1,0 m in the GEO region. They possess a
sufficiently great potential energy (e.g., the pressurized gas containers, the fuel in tanks and
propulsion systems, batteries, etc.), which can be scattered about as a result of an explosion
under the following adverse circumstances:
The SO explosion results in generation of splinters (including the numerous small solid
particles), which as a cloud of fragments will represent a threat for the existence of both the
functioning spacecraft near the explosion zone and other large man-made objects, which
possess the dangerous potential destructive energy with the subsequent generation of new
splinters.
After an explosion one large object can generate from ten to hundreds of other smaller
objects. The process and features of such destruction are unpredictable, but they depend on
several factors, among them on the design of the object and characteristics of a source of the
explosion, on its energy, the attitude, etc. Therefore, various calculation techniques are
developed and investigated to estimate the amount of the generated splinters, and the parameters of their scattering (the dynamics of their movement). The results of these
calculations are compared to the separate data available from the natural experiments.
Among the entire variety of the problems that are posed by the existence of the man-
made conditions in the GEO, the problem of the creation of a reliable spacecraft is the main
one for S/C developers. The design of a spacecraft should stand all kinds of probable
influences, including the influence of the meteoroid and man-made objects (MMO) in the
required operation terms.
2. TRADITIONAL METHOD OF THE MAN-MADE CONDITIONS DETERMINATIONThere are the three following basic trends in studies of a problem related to the presence of
the man-caused conditions in the GEO region:
By the existing strong restrictions put on the weight of a spacecraft to be launched and
its subsystems, the problem of construction of a reliable S/C protection against the MMO
influence is a difficult and multilevel one, since it assumes the consistent optimization of the
final solution on all stages of the protection design and adjustment.
Let's note that currently the traditional method of modeling the man-made conditions in
the GEO region for projected S/C is realized, and then this model is accounted for when the
protection of the S/C against the meteoroid and man-made objects is developed. The method
is based on the use of the research results of the first two trends. Its distinctive feature is the
use of the data about existing catalogued large (the diameter ≥ 1,0 m) man-made objects in
the GEO in the model, as a key parameter for the realization of assumptions about the
corresponding distribution of the smaller man-made objects. Such an approach is justified by
the fact that it is not obviously possible yet to systematize, and furthermore to catalogue,
small (the diameter ≤ 0,5 m) man-made objects, because of their great distances from ground-
based surveillance facilities, and of the imperfection of measuring devices (i.e. for the lack of
the necessary volume of the statistical data). Now the results of separate successful
measurements of parameters of the non-catalogued small man-made objects available from
some observers are collected for further carrying out statistical generalizations. The
insufficient scrutiny level for the distribution features of small man-made objects in the GEO
region is a basic obstacle, which does not allow to construct a reliable mathematical model for
the man-made conditions in this space region.
So, when estimating the man-made conditions for a projected S/C (for the required
station in the GEO), the results obtained by the traditional method, i.e. by considering the
distribution of the known data about the catalogued large space objects which are
representatives and sources of the man-made objects, are used as the initial ones. In this case such a “from the general to the particular” approach allows to receive only the preliminary
average data about the minimum level of probable man-made influences on the spacecraft (the
estimate from below). The averaging does not even take into account the non-uniformity of
distribution of the catalogued objects in the GEO longitude. This can only lead to the unfairly
optimistic results, i.e. to the choice of a simplified device to protect the S/C against man-made
objects.
3. RESEARCH OF THE DYNAMICS OF MAN-MADE CONDITIONSTo choose a reliable plan of a protection design for a spacecraft developed for long term
operations in the GEO region (up to 10 years and more), it is necessary to increase the
accuracy of the model for determination of the man-made conditions in this region, as
compared with results obtained by the method considered above. It is proposed to solve this
problem for the “Electro-L” meteorological satellite (Fig. 1) created by the Lavochkin
Association by carrying out special regular researches of the man-made conditions (the stream
density) in the vicinity of the required longitude slot of this satellite (76° East). The satellite
will be in unfavorable conditions, i.e. not far from the Eastern stable libration point (75° East)
with the maximal streams of working objects on this orbit, the large (catalogued) and the
small (not catalogued) ones. The long research of the man-made conditions in the limited
GEO region, but using the various surveillance means should allow to receive the most
complete data about the features and the dynamics of man-made conditions in the concrete
limited GEO region in a rather short time. It is planned to use the generalized results of this
surveillance to specify the meteoroid and man-made condition model for the “Electro-L”
satellite at a stage of the protection means improvement.
It is considered, that such a concept – the target research of the dynamics of man-made
conditions in the required GEO region (for the concrete spacecraft) – will allow to adjust the
technique and technology of the surveillance, to improve the surveillance facilities, and to
intercompare in the future the data obtained by various researchers to increase the reliability
and certainty of the final results.
The prospective approach should serve as more effective utilization of surveillance
facilities for the decision with respect to the deadlines of an individual applied problem - to
specify the real man-made conditions in the required GEO region. The application of the
concept to similar problems but in other GEO regions, will serve to perfect its methodology,
and the generalization of new similar results will help to specify some ideas, accepted now
about features of the man-made conditions in the GEO region.
![]() Fig. 1. An artistic view of the “Electro-L” satellite.
Ðàçìåùåí 10 äåêàáðÿ 2006.
