USING EOP AND SPACE WEATHER DATA FOR SATELLITE OPERATIONSDavid A. Vallado1 and T. S. Kelso21 Technical Program Manager, Analytical Graphics Inc., Center for Space Standards and Innovation, 7150 Campus Dr., Suite 260, Colorado Springs, Co, 80920-6522. e-mail: dvallado@centerforspace.com
Phone 719-573-2600, direct 610-981-8614, FAX 719-573-9079 2 Technical Program Manager, Analytical Graphics Inc., Center for Space Standards and Innovation, 7150 Campus Dr., Suite 260, Colorado Springs, Co, 80920-6522. e-mail: tskelso@centerforspace.com Phone 719-573-2600, direct 610-981-8615, FAX 719-573-9079
INTRODUCTIONThe use of numerically generated state vectors for satellite operations is not new to
astrodynamics. However, with the first numerically generated space catalog by the U.S. Navy
in 1997 (Coffey and Neal, 1998), the potential to replace the existing TLEs with numerical
results is feasible. This poses some unique challenges for the astrodynamics community. The
historical TLE operations used analytically generated datasets which either ignored or
approximated the precise coordinate system and force models required to accurately model
the satellite. Numerical operations require precise adherence to a coordinate system and
specific force models.
Earth Orientation Parameters (EOP) data is a cornerstone for accomplishing the inertial
to fixed transformation of coordinates. Most numerical integrators integrate in an inertial
frame, while the force models are applied in a fixed frame. The EOP information consists of ΔUT1, the difference between UT1 (Universal time) and UTC (Coordinated Universal time),
the length of day, polar motion coefficients (xp, yp) describing the movement of the Earth’s
rotation axis to the crust, and AT, the number of leap seconds between UTC and TAI
(Atomic time). There are typically small differences between sources of EOP data (e.g.,
International Earth Rotation Service - IERS, National Geospatial Intelligence Agency - NGA,
and US Naval Observatory - USNO), but the impact on overall accuracy is usually small (a
few meters or so).
Space weather data is the primary input, other than satellite characteristics, for
atmospheric drag models. Even the smallest changes in space weather data can have large
effects during propagation.
OBJECTIVEThis paper investigates the available data, compares products within and between
organizations, and provides recommendations on which data should be used for past, present,
and future satellite operations. Specific instructions are provided to assemble the data into
input data files and the location of completed files on the Internet is discussed.
BACKGROUNDEarth Orientation Parameters (EOP):The EOP data assists in the transformation between inertial and fixed coordinate systems. For this paper, we’ll simply use Earth Centered Inertial (ECI) and Earth Centered Earth Fixed
(ECEF) to denote the two systems, respectively. Figure 1 shows a notional representation of
the FK5 and IAU2000 coordinate systems. EOP data is the foundation of these calculations.
Fig. 1. Coordinate System Representation. These plots show the general schematic
for transforming vectors in the FK5 and IAU2000 coordinate systems. The
primary objective is the transformation between inertial and fixed coordinate
systems. Polar motion, sidereal time (indirectly), and nutation all use EOP data
for solution.
The specific equations are lengthy (Vallado 2004, 205-228), but in summary form, the
EOP data enables every operation beginning with the initial determination of the various time
systems. Recognize that the time arguments are found using EOP, and these in turn are used
to determine the remaining coefficients of each transformation. For IAU 2000,
![]() Space Weather Data:The space weather data consists primarily of the geomagnetic indices (kp, ap), and the solar
flux (F10.7). These indices provide atmospheric models with the necessary information to
predict the atmospheric density for orbital calculations. Although the space weather data has a
huge impact on the ultimate value of atmospheric density and there has been significant study
over the years, the models are less than perfect. As Vallado (2005) showed, atmospheric
propagation results can differ by 50-100 km simply by how the space weather parameters are
treated within a program. The causes for these large discrepancies are varied, but include
severely limited observational data with which researchers can investigate the phenomenon,
lack of good reference orbits, and lack of time and money to complete such studies. Vallado
(2005) remarks that there is not a standard method of treating the data, but provides a
proposed solution. Whatever the cause, it is appropriate to use the available information in the
best way possible to maximize the chances of success for each use.
For atmospheric drag, the acceleration is simply one of many that are numerically
integrated. The following equation shows this.
![]() If we examine a particular density model, say the Jacchia 1970 model, the space
weather data parameters (F7.10, F7.10, pk) are used in several equations for exospheric
temperature
![]() and density
![]() EOP ANALYSIS AND DISCUSSIONThe EOP data comes from three general sources: IERS, USNO, and NGA. Each covers a
different time period, and some of the quantities are available only in certain data files. Figure
2 shows the time spans and available information. Note that satellite operations require
seamless integration of this information.
![]() Fig. 2. Earth Orientation Parameter Data Availability. There are several sources of
data we can use to populate a database of values for use in past, present, and
future operations. File names are included from each source.
Each data provider gives slightly different information, although the core information is
the same. For IERS, the data are (there is a corresponding file for the IAU2000 theory,
containing corrections, ΔX and ΔY instead of δΔΨ (dPsi) and δΔε (dEpsilon):
INTERNATIONAL EARTH ROTATION SERVICE
EARTH ROTATION PARAMETERS
EOP (IERS) C 04
FORMAT(2X,I4,2X,A4,I3,2X,I5,2F9.6,F10.7,2X,F10.7,2X,2F9.6)
Date MJD x y UT1-UTC LOD dPsi dEpsilon
" " s s " "
(0h UTC )
2004 JAN 1 53005 .031278 .153770 -.3895858 .0004983 -.054858 .000651
2004 JAN 2 53006 .028867 .153565 -.3900835 .0004346 -.055216 .000514
2004 JAN 3 53007 .026698 .153749 -.3904490 .0002619 -.055428 .000234
2004 JAN 4 53008 .024239 .154234 -.3906090 .0000719 -.055490 -.000096
The USNO also provides EOP data in the Bulletins A and B. Bulletin A contains the
rapid results while Bulletin B contains the finalized results. There are two files, one for FK5,
and one for IAU2000. It’s significant to note that the USNO data is column specific, and it
includes error estimates on the parameters, but no finalized value for the length of day. We’ve
added column headings below (highlighted) to indicate which variables are listed. The file
finals.all contains both the timing and polar motion values from January 2, 1973 to date,
including about one year of predicted values.
Bulletin A from May 5
Date MJD xp err yp err DUT1 err lod err dpsi err deps err 4 1 1 53005.00 I .031244 .000048 .153837 .000038 I -.3896242 .0000036 0.4944 0.0025I -56.182 .288 -.356 .340 4 1 2 53006.00 I .028844 .000055 .153666 .000035 I -.3900898 .0000036 0.4219 0.0037I -56.267 .288 -.447 .340 4 1 3 53007.00 I .026642 .000053 .153845 .000027 I -.3904388 .0000065 0.2618 0.0029I -56.230 .740 -.510 .340 4 1 4 53008.00 I .024196 .000061 .154296 .000027 I -.3906064 .0000045 0.0807 0.0040I -56.014 .244 -.595 .340 4 1 5 53009.00 I .021488 .000060 .154846 .000020 I -.3906172 .0000046 -0.0493 0.0033I -55.791 .244 -.810 .340 4 1 6 53010.00 I .018791 .000059 .155474 .000036 I -.3905345 .0000048 -0.0993 0.0034I -55.682 .285 -1.079 .340 The Bulletin B values are in the same file as the Bulletin A values (at the end of each
line). The finalized data lags about one to two months.
Bulletin B from May 5
Date Bulletin A xp yp DUT1 dpsi deps … 0.031250 0.153770 -0.3895920 -56.100 -0.100 0.028870 0.153550 -0.3900740 -56.100 -0.200 0.026700 0.153740 -0.3904550 -56.000 -0.400 0.024260 0.154230 -0.3906300 -55.900 -0.600 0.021590 0.154800 -0.3906200 -55.700 -0.900 0.018790 0.155440 -0.3905240 -55.500 -1.000 Before analyzing the data, it’s useful to understand the behavior of the data over time.
Figure 3 shows the various parameters for the last several decades.
![]() Fig. 3. Historical EOP Values. This figure shows the EOP parameters from 1962.
Notice the centered motion about zero for xp, the slight secular increase for yp,
and the continual downward trend for UT1. The large vertical spikes show the
occurrences of leap seconds. The final 3 parameters (length of day and FK5
corrections) are very small.
Comparisons between Bulletins A and B are possible as they contain similar
parameters. The Bulletin A values “should” exhibit additional variations as they are the rapid
calculations. However, this was not always supported by the data. Consider the following
figures.
![]() Fig. 4. USNO Comparisons between Bulletin A and Bulletin B Data. Differences in
the Bulletin A and B correction parameter values for the FK5 and IAU2000
theories are shown. Data is available for FK5 from Jan 2, 1973 and for
IAU2000 from Jan 1, 1989. Older data shows larger differences as the current
theories didn’t exist during those times. However, notice the unusual spike in
the Bulletin B data for deps and dX. Both of these occur in about the September
1999 timeframe.
Although the differences show in a graph with a small scale, the relative difference in
these parameters is remarkably small.
Next, we can examine similar parameters between the USNO and IERS (EOPC04) data.
![]() Fig. 5. IERS and USNO EOP Comparisons. The IERS and USNO values for polar
motion, delta time, and length of day are shown. Notice the similarity of the
values after about 1997. The last few daily values from USNO exhibit
additional variation over the comparable IERS values, as shown in the right-
hand plot.
The data in Fig. 5 were taken in late February 2005. By May, the final values were
available. For the last few days’ values, Table 1 lists the results.
Table 1. IERS and USNO Point Comparisons. The difference between
predicted and observed values is illustrated for February 22, 2005. Notice the
“consistent” nature of the IERS results over time, while the USNO results appear
to change more.
Comparing the corrections to FK5 and IAU2000 theories between IERS and USNO,
![]() Fig. 6. IERS and USNO Correction Comparisons. These parameters show little
variation, although the Bulletin A values seem to exhibit slightly more
variation, as would be expected.
The IERS provides uncertainties for each of the EOP parameters, shown in Table 2.
These values are all within the differences seen in the previous figures.
Table 2. Earth Orientation Parameter Data Accuracy. This table lists the
expected accuracy of the EOP parameters for several different time periods. The
units are given with each quantity.
Some operational programs rely on the NGA coefficients. For the current week,
predictions of xp, yp, and ΔUT1 are available from NGA in the form of polynomials. The
information is updated every Thursday. The pole positions are accurate to about 0.01'' after a
month, and ΔUT1 predictions are accurate to a few milliseconds after about 20 days.
Although pole positions may be calculated many months into the future, the same operation
for ΔUT1 is not recommended.
The NGA Earth Orientation Parameter Prediction (EOPP) files are ASCII files named
eoppyddd.txt where ddd is the day of year for the following Sunday (e.g., EOPP5205.TXT is
calendar day 205, 24 July, of 2005). This is a new format as of 2005 week 25, replacing the
older eoppyww.txt where y was the last digit of the year and ww was the week (Sunday,
which differed from the ISO definition of the week) of the year (e.g., EOPP402.TXT is week
02 of 2004). The predictions are calculated on Thursday of each week (Wednesday when a
federal holiday falls on a Thursday) to go into effect on the following Sunday. Single daily
values are given after the coefficients. NGA re-introduced inclusion of zonal tide corrections
into the data beginning with week 2 of 2005. This may change the accuracy slightly.
53154.00 .056293 .000000 .079979 .034045 -.028833 -.113721365.25 435.00 .343292 .000000 .030247 .117765 .083031 .026326365.25435.00 53370.00 -.523010 -.000381 .000514 -.000831 -.022000 .006000 .000607 .000855 .012000 -.007000 27.5600 13.6600 365.2500 182.6250 32 5205 53575 53572 53575 -.013034 .417876 -.6043788 53576 -.011681 .418738 -.6046355 53577 -.010318 .419577 -.6049358 53578 -.008945 .420394 -.6051611 There is not much information given with the parameters, although the readme file
(http://earth-info.nga.mil/GandG/sathtml/eoppdoc.html) explains each field. The information
is presented below for convenience. There are several constants in the file – the annual period,
AnnPer = 365.25, Chandler period, ChnPer = 435.0, semi-annual period, SAnnPer = 182.625.
Using a FORTRAN format statement and the variable names, each line is
FORMAT( F10.2, 6(F10.6), F6.2 ) -> ta, A, B, C1, C2, D1, D2, P1 FORMAT( F6.2, 6(F10.6), 2(F6.2) ) -> P2, E, F, G1, G2, H1, H2, Q1, Q2 FORMAT( F10.2, 6(F10.6) ) -> tb, I, J, K1, K2, K3, K4 FORMAT( 4(F10.6), 4(F9.4 ) -> L1, L2, L3, L4, R1, R2, R3, R4 FORMAT( I4, I5, I6 ) -> dat, EOPPWk, teff These coefficients are used with the following equations to obtain estimates of the EOP
parameters at any time (t – the current time in MJD).
![]() If we examine several runs of the data, we see the results in Fig. 7. Note in particular the
lines for ΔUT1 in which the values increases over time. Extrapolating this for several months
or a year is not recommended.
![]() Fig. 7. Long-Term EOP Coefficient Performance. Numerous weekly coefficients
were used to calculate values that were then compared to actual EOP
measurements. Notice that the week before the week of applicability shows the
best match – a consequence of least squares processing.
Finally, leap seconds are included in the combined EOP file. Information is gathered
from the Bulletin C that announces these periodic updates –
ftp://hpiers.obspm.fr/iers/bul/bulc/bulletinc.dat. Be aware that the predicted EOP data doesn’t immediately include this information.
Earth Orientation Parameters (EOP) Summary:The most consistent set of final smoothed Earth Orientation Parameters (xp, yp, ΔUT1, LOD)
to within 1 day of the current time are available from IERS. The IERS Bulletins A (published
weekly, includes one-year predictions for xp, yp, ΔUT1). The NGA data supports the current week only.
# Observed data
# 1. Current data - updated daily # http://hpiers.obspm.fr/eoppc/eop/eopc04/eopc04.62-now # http://hpiers.obspm.fr/eoppc/eop/eopc04/eopc04_IAU2000.62-now # Documentation can be found at: # http://hpiers.obspm.fr/eoppc/eop/eopc04/EOPC04.GUIDE # # Predicted data (to +90 days) Bulletin A # 2. Current data - updated daily # http://maia.usno.navy.mil/ser7/finals.daily # http://maia.usno.navy.mil/ser7/finals2000A.daily # # Predicted Data (to +1 year) Bulletin A # 3. Current data - updated weekly # http://maia.usno.navy.mil/ser7/finals.all # http://maia.usno.navy.mil/ser7/finals2000A.all # # Documentation for Bulletin A can be found at: # http://maia.usno.navy.mil/ser7/readme.bulla # http://maia.usno.navy.mil/ser7/readme.finals # http://maia.usno.navy.mil/ser7/readme.finals2000A # # 4. Current data - updated weekly (Thursday # ftp://164.214.2.65/pub/gig/pedata/EOPPyyyy/EOPPyddd.TXT # Documentation can be found at: # http://earth-info.nima.mil/GandG/sathtml/eoppdoc.html SPACE WEATHER DATA ANALYSIS AND DISCUSSIONSpace weather data are available through the National Geophysical Data Center (NGDC) in the National Oceanic and Atmospheric Administration (NOAA), but there are several files
necessary to piece together a complete data file. We can show a schematic for what data are
available for propagation activities. Because 3-hourly data are available for the geomagnetic
indices, a truly current file requires frequent retrieval and organization of the data. Figure 8
shows the various files and their time of applicability.
![]() Fig. 8. Space Weather Parameter Data Availability. There are several sources of
data we can use to populate a database of values for use in past and future
propagations. Satellite operations require seamless integration of this
information.
There are several things to consider when examining the atmospheric data. First, it’s
instructive to review the sensitivity of orbits to the incoming data (see Vallado 2005). It’s also
important to look at the trends in the data. This leads to a discussion of predicted values – a
topic that always evokes varied responses. Finally, we need to determine how to “splice” the
available data together. Vallado (2004, App D) discusses the various files needed for space
weather data selection.
NOAA provides actual and predicted atmospheric parameters. The files for a
particular year are designated as yyyy where yyyy is the year. Data within the current year are
indicated with a version extension for the month, for instance 2004.v5 includes data through
the end of May in 2004. The data are given to within about one month of the current time
(data from Feb 22, 2005, and the header is added for clarity of variables). Note that the F10.7 values are valid at 1700 UT to May 31, 1991. From that time to the present, the values are for
2000 UT, measured at the Penticton site in Canada. All data are adjusted to 1.0 AU.
YrMoDy kp avg ap sum f10.7 0501212340183320232327678073347 18 7 9 9 12111207154 661.77 45109.90 0501222340195760372737334030320 67 80 22 12 22 18 27 15 331.36 31 99.10 0501232340203737332733402733267 22 22 18 12 18 27 12 18 191.05 26 92.80 0501242340213017172030302017180 15 6 6 7 15 15 7 6 100.52 28 91.70 05012523402210 31010 7101710 77 4 2 4 4 3 4 6 4 40.10 32 91.20 050126234023 7 3 3 7 7 3 7 7 43 3 2 2 3 3 2 3 3 30.00 23 86.60 050127234024 3 0 3 3 0 71013 40 2 0 2 2 0 3 4 5 20.00 20 84.30 0501282340252317 7 7 7 72727120 9 6 3 3 3 3 12 12 60.31 20 82.40 0501292340263320304033304043270 18 7 15 27 18 15 27 32 201.05 19 83.90 0501302340274043303330272020243 27 32 15 18 15 12 7 7 170.94 22 82.90 0501312341 133273037474030 7250 18 12 15 22 39 27 15 3 191.05 23 83.60 For the last month or so, solar and geomagnetic data files are required. The quarterly
solar data provides only the daily F10.7 values.
:Product: Daily Solar Data quar_DSD.txt :Issued: 1425 UT 22 Feb 2005 # # Prepared by the U.S. Dept. of Commerce, NOAA, Space Environment Center. # Please send comments and suggestions to SEC.Webmaster@noaa.gov # # Quarterly Daily Solar Data # # Sunspot Stanford GOES12 # Radio SESC Area Solar X-Ray ------ Flares ------ # Flux Sunspot 10E-6 New Mean Bkgd X-Ray Optical # Date 10.7cm Number Hemis. Regions Field Flux C M X S 1 2 3 #--------------------------------------------------------------------------- 2005 01 01 99 51 230 0 -999 B1.3 1 0 1 1 0 0 0 2005 01 02 100 52 250 0 -999 B1.9 2 0 0 0 0 0 0 2005 01 03 94 43 160 0 -999 B1.4 3 0 0 1 0 0 0 … 2005 02 16 113 61 720 0 -999 B1.4 2 0 0 1 1 0 0 2005 02 17 111 51 620 0 -999 B1.3 1 0 0 0 0 0 0 2005 02 18 104 46 590 0 -999 B2.1 5 0 0 1 0 0 0 2005 02 19 99 51 520 0 -999 B1.6 1 1 0 0 0 0 0 2005 02 20 96 60 580 1 -999 A7.0 0 0 0 0 0 0 0 2005 02 21 95 33 560 0 -999 A9.9 0 0 0 0 0 0 0 2005 02 22 -1 -1 0 -1 -999 * 0 0 0 0 0 0 0 The geomagnetic data provide the 3-hourly kp and daily ap values. Notice that the 3-hourly ap values are not given.
:Product: Daily Geomagnetic Data quar_DGD.txt
:Issued: 1830 UT 22 Feb 2005
# Please send comment and suggestions to SEC.Webmaster@noaa.gov
# Current Quarter Daily Geomagnetic Data
Middle Latitude High Latitude Estimated
- Fredericksburg - ---- College ---- --- Planetary ---
Date A K-indices A K-indices A K-indices
2005 01 01 10 1 3 2 2 2 2 3 3 34 4 5 3 4 5 3 6 3 15 1 4 3 2 3 3 4 3
2005 01 02 20 3 3 3 3 2 4 3 5 64 2 3 7 6 5 7 4 5 33 4 4 5 4 3 5 3 5
2005 01 03 14 3 3 2 3 4 3 2 2 44 3 3 6 6 6 5 4 2 22 4 4 3 3 5 4 3 2
2005 01 31 15 3 2 3 4 4 3 2 1 43 2 2 3 6 7 6 3 1 19 3 2 3 4 5 4 3 1
2005 02 01 4 3 0 1 1 1 1 1 1 6 2 0 0 3 3 2 0 1 6 3 0 1 2 1 2 2 2
2005 02 02 7 1 2 2 2 1 2 3 1 8 0 0 3 3 2 3 2 1 8 1 1 3 2 2 2 3 1
2005 02 03 5 1 3 2 1 1 1 1 0 9 0 4 4 3 1 0 1 0 8 1 4 3 1 1 2 1 1
2005 02 20 6 3 2 2 0 1 1 2 2 16 4 3 3 1 3 4 3 2 12 4 3 3 0 2 3 2 2
2005 02 21 4 3 2 2 0 1 0 0 1 18 2 3 3 4 4 2 4 3 8 3 3 1 2 1 2 1 2
2005 02 22 -1 -1-1-1-1-1-1-1-1 -1 -1-1-1-1-1-1-1-1 -1 1 1 0 0 1 2-1-1
Predicted values of solar activity are very useful. The predictions for the next 45 days
are found in the 45df.txt file. Notice there are only single daily values, and no kp values.
:Product: 45 Day AP Forecast 45DF.txt :Issued: 2005 Feb 21 2059 UT # Prepared by the U.S. Air Force. # Retransmitted by the Dept. of Commerce, NOAA, Space Environment Center. # Please send comments and suggestions to SEC.Webmaster@noaa.gov # # 45-Day AP and F10.7cm Flux Forecast #------------------------------------------------------------- 45-DAY AP FORECAST 22FEB05 010 23FEB05 012 24FEB05 012 25FEB05 012 26FEB05 012 27FEB05 012 28FEB05 015 01MAR05 020 02MAR05 008 03MAR05 008 04MAR05 008 05MAR05 008 06MAR05 012 07MAR05 025 08MAR05 015 09MAR05 012 10MAR05 010 11MAR05 010 12MAR05 008 13MAR05 010 14MAR05 008 15MAR05 008 16MAR05 012 17MAR05 015 18MAR05 012 19MAR05 010 20MAR05 005 21MAR05 005 22MAR05 008 23MAR05 015 24MAR05 025 25MAR05 020 26MAR05 020 27MAR05 020 28MAR05 008 29MAR05 008 30MAR05 008 31MAR05 008 01APR05 008 02APR05 012 03APR05 025 04APR05 015 05APR05 012 06APR05 010 07APR05 010 45-DAY F10.7 CM FLUX FORECAST 22FEB05 095 23FEB05 090 24FEB05 085 25FEB05 085 26FEB05 085 27FEB05 085 28FEB05 090 01MAR05 085 02MAR05 085 03MAR05 085 04MAR05 085 05MAR05 090 06MAR05 090 07MAR05 095 08MAR05 095 09MAR05 100 10MAR05 100 11MAR05 100 12MAR05 100 13MAR05 100 14MAR05 100 15MAR05 100 16MAR05 100 17MAR05 100 18MAR05 095 19MAR05 095 20MAR05 090 21MAR05 090 22MAR05 085 23MAR05 085 24MAR05 085 25MAR05 085 26MAR05 085 27MAR05 085 28MAR05 085 29MAR05 085 30MAR05 085 31MAR05 085 01APR05 085 02APR05 085 03APR05 090 04APR05 090 05APR05 095 06APR05 095 07APR05 095 Long-range predictions (about 6 years into the future) are found in the predict.txt file.
Notice there are no long-range geomagnetic predictions, and the solar flux has only a single
value for each month. Given the difficulty in accurately predicting the geomagnetic indices,
this is to be expected.
:Predicted_Sunspot_Numbers_and_Radio_Flux: Predict.txt :Created: 2005 Feb 01 1800 UTC # Prepared by the U.S. Dept. of Commerce, NOAA, Space Environment Center (SEC). # Please send comments and suggestions to sec.webmaster@noaa.gov # # Sunspot Number: S.I.D.C. Brussels International Sunspot Number. # 10.7cm Radio Flux value: Penticton, B.C. Canada. # Prediction values are based on ISES cycle 23 forecast of 13-month running # smoothed values. # Current interpolation prepared by IPS Radio and Space Services, Australia # # Missing or not applicable data: -1.0 # # Predicted Sunspot Number And Radio Flux Values # With Expected Ranges # # -----Sunspot Number------ ----10.7 cm Radio Flux---- # YR MO PREDICTED HIGH LOW PREDICTED HIGH LOW #-------------------------------------------------------------- 2004 08 38.9 39.9 37.9 104.2 105.2 103.2 2004 09 36.5 39.5 33.5 101.6 104.6 98.6 2004 10 34.3 39.3 29.3 99.1 104.1 94.1 … 2007 10 15.6 30.6 0.6 75.7 98.7 52.7 2007 11 18.3 33.3 3.3 77.4 100.4 54.4 2007 12 21.3 36.3 6.3 79.4 102.4 56.4 Finally, it’s important to realize that the solar flux data may be either observed (at the
true Sun-Earth distance), or adjusted to 1.0 AU. The raw observed data (and adjusted in
DAILYPLT.ADJ) may be found at
ftp://ftp.ngdc.noaa.gov/STP/SOLAR_DATA/SOLAR_RADIO/FLUX/DAILYPLT.OBS
and the conversion uses the current Earth-Sun distance (rearth-sun) and the AU
(149,597,870.66km).
![]() Although this difference is small, some atmospheric models specifically require the
solar flux at the true Earth-Sun distance. Therefore, our file includes both sets of data. The
difference is large enough to require separate values for the 81-day average, and because
many programs use either the centered or trailing 81-day averages, a total of six values are
required for the solar flux.
Also note that the values found in the GEOMAGNETIC and the SOLAR FLUX
directories on NGDC do not agree completely because they are actually different data. The
GEOMAGNETIC files contain Lenhart adjusted data while the SOLAR FLUX files contain
observed and adjusted Dominion Radio Astrophysical Observatory (DRAO) data (Knapp,
2005). The observed minus adjusted values of solar flux are shown in Fig. 9. The data spikes
appear to be random in that no single data source appears to be “correct” for all times.
Communication has been established with NGDC to better understand the differences and
develop a common baseline for use.
![]() Fig. 9. Difference of Observed and Adjusted Solar Flux Values. The solar cycles
are evident in the observed minus adjusted solar flux differences, along with the
seasonal variations that drive the original variations over time. The data spikes
occur in both observed and adjusted values, and in the DRAO and Lenhart data
for a variety of reasons including multiple Sun-Earth distance corrections.
Determining kp and ap valuesCareful examination of the preceding data files reveals that there is not a single source that
provides both kp and ap values for all periods. Thus, a practical means of converting between kp
and ap is needed. Many papers have been written on this topic. Tanygin and Wright (2004)
discuss the importance of interpolating these data with respect to filter applications and
include an iterative approach based on a technical definition in the development of an
atmospheric model (Jacchia, 1970). The process of finding kp and ap may seem easy at first,
but on closer inspection, there are several nuances. Any approach should be able to convert in
both directions—thus closure is important.
The primary problem arises from the need to determine values of kp and ap at a
continuous number of time points, other than those actually measured. In over 50 years of
recorded space weather data, there are only discrete recorded values of kp and ap quantities.
Chapman and Bartels (1940) originally defined these discrete values. Note the plus and minus
indicators represent 1/3 values and should not be rounded.
kp 0o, 0+, 1-, 1o, 1+, 2-, 2o, 2+, 2-, kp 0.0, 0.333, 0.667, 1.0, 1.333, 1.667, 2.0, 2.333, 2.667, ap 0 2 3 4 5 6 7 9 12 ------------------------------------------------------------ kp 3o, 3+, 4-, 4o, 4+, 5-, 5o, 5+, 6-, kp 3.0, 3.333, 3.667, 4.0, 4.333, 4.667, 5.0, 5.333, 5.667, ap 15 18 22 27 32 39 48 56 67 ------------------------------------------------------------ kp 6o, 6+, 7-, 7o, 7+, 8-, 8o, 8+, 9-, 9o kp 6.0, 6.333, 6.667, 7.0, 7.333, 7.667, 8.0, 8.333, 8.667, 9.0 ap 80 94 111 132 154 179 207 236 300 400 If one examines a plot of the quantities, it’s readily apparent that the relation is not
linear.
![]() Fig. 10. Relationship between ap and kp. The semi-logarithmic correlation between ap
and kp is shown. Note that there are only distinct values that correspond
between each scale and kp is multiplied by 10.0.
Two practical problems arise. For the last month, only the 3-hourly kp values are given,
but any atmospheric model using ap will need to convert the values, and when the values are
finalized, they will be from the set of discrete values mentioned above. The second difficulty
arises when assembling the predicted data, for which only ap data are available. Specifically,
values of ap occur that do not have an exact corresponding kp value per Chapman and Bartels
(1940). To consistently use the data, a standard technique should be employed to convert the
data to and from the ap and kp values, for both of these situations.
It could be argued that the indices have enough variability that to go to extreme lengths
to preserve the original data is not fruitful. While the data are seriously lacking in rigor, they
represent the best existing indices we have, and the one that all the models have been
developed to over the years. As such, it would be unwise not to use the data as it’s known
today by introducing additional uncertainty in processing the data in a different manner.
However, if there is a demonstrated benefit of not using the existing defined values, NOAA
should take the lead in changing the existing data to better support mission operations.
We explored several conversion approaches—a linear interpolation, an iterative
approach, and two splining approaches (“Spline” by Press et al., 1992 and “Cubic” by
Vallado 2004, 900). The iterative approach was introduced by Tanygin and Wright (2004)
and it derives from Jacchia (1970). Comparing these approaches, there are large differences at
the higher values of kp, and many discrepancies throughout the interval. Vallado (2005)
showed that numerical propagation relies heavily on the treatment of these data, so even small
variations in the values could cause very different propagated results. Remember however,
the indices themselves are not exact, and simply using them introduces uncertainty.
![]() Fig. 11. ap Difference Values between Conversion Techniques. Differences in ap results for several interpolation techniques are shown. Values from iteration,
linear interpolation, and splining techniques are differenced.
If we now examine the ability of each technique to replicate the original discrete values,
we see that there are several large differences from the defined points. Note that the
conversion is not always equal in both directions as the number of points for kp is more evenly
distributed than for ap.
![]() Fig. 12. Comparison of Conversion Techniques to Exact Values. The exact values
are the defined points of the scale by Chapman and Bartels (1940). Notice the
discrepancy of the iterative approach, especially at the high kp values (left). The
ap performance is a little better (right). All the other points lie on the zero
horizontal axis.
The closure of iterative, interpolated, and cubic splining (Vallado, 2004, 900) values
were exact, but the Numerical Recipes “Spline” technique showed some small variations.
Note that the scale in Fig. 13 is significantly smaller than the previous graphs.
![]() Fig. 13. Closure Properties for Numerical Recipes “Spline” Technique. kp and ap closure properties are shown (left and right). There appear to be problems at
some kp and ap values, but the scales are very small compared to differences
from other interpolation techniques. The exact values all lie on the zero
horizontal axis.
It appears that the cubic splining technique best replicates the observed data values,
while simultaneously maintaining closure properties. The approach for the cubic spline
(Vallado, 2004, 900) are shown below (note this is modified to match all four points instead
of 2 points and slope).
Setup arrays of ap = [0 2 3 4 5 6 7 8 12 …], kp = [0 0.33333 0.66667 1 1.33333 1.666667 …]
Locate input kp or ap within the appropriate array given apin or kpin (respectively)
Determine the 4 points for kp and ap (bracketing the input kpin or apin)
kp1, kp2, kp3, kp4, ap1, ap2, ap3, ap4
Form coefficients for the cubic polynomials (one for ap and one for kp)
k0 = kp2 a0 = ap2
k1 = -kp1/3.0 - 0.5*kp2 + kp3 - kp4/6.0 a1 = -ap1/3.0 - 0.5*ap2 + ap3 - ap4/6.0
k2 = 0.5*kp1 - kp2 + 0.5*kp3 a2 = 0.5*ap1 - ap2 + 0.5*ap3
k3 = -kp1/6.0 + 0.5*kp2 - 0.5*kp3 + kp4/6.0 a3 = -ap1/6.0 + 0.5*ap2 - 0.5*ap3 + ap4/6.0
Solve the cubic polynomial for the real root (x) between 0.0 and 1.0 for either kp or ap (both
are shown for completeness)
3 2 3 2
0 = k3x + k2x + k1x + k0 – kpin 0 = a3x + a2x + a1x + a0 – apin
Solve for either the ap or kp value (both are shown for completeness)
3 2 3 2
apout = a3x + a2x + a1x + a0 – kpin kpout = k3x + k2x + k1x + k0 - apin
Long-Term PredictionsThe long-term prediction of solar flux values is important for mission planning operations.
However, the predictions are a complex analysis and combination of sunspot and
geomagnetic activity, comparison to existing knowledge of solar activity since the 1700s, and
several other factors (Hathaway et al., 1999). As such, the predictions have a great deal of
uncertainty. Our goal was to find a simple, but “reasonably” accurate approach to determining
long-term trends. We wanted to incorporate the existing prediction methods in the short-term,
and use alternate approaches for the long-term (decades).
A commonly accepted set of predictions are the Schatten files. These files are available
from the following website (password required) ftp://fdf.gsfc.nasa.gov/generalProducts/database/. The
files generally span about one solar cycle and are periodically re-issued (about 3 to 4 times
per year) to provide improved accuracy to the observed progress of each solar cycle. This is
sufficient for many planning operations.
Vallado (2004: 535) introduced a polynomial trend that covers several solar cycles (t is the number of days from Jan 1, 1981). Note that the coefficients have been updated slightly
from Vallado 2004 to better match the solar min region.
F10.7 = 145 + 75*COS{ 0.001696 t + 0.35*SIN(0.001696 t )}
Figure 14 shows the solar flux and geomagnetic values over several solar cycles with
the polynomial trend and centered 81-day average solar flux.
![]() Fig. 14. Solar Flux Historical Values. Solar cycles are shown from 1950 with the
polynomial trend and centered 81-day average. The average ap values are
shown at the bottom. The solar cycle numbers begin in about 1750 when
recorded sunspot data became routinely available.
Figure 15 shows the Schatten predictions with the actual and polynomial trend data.
Because the Schatten predictions provide only monthly estimates of the solar flux,
comparisons were made to the actual data over that same time.
![]() Fig. 15. Recent Schatten Predictions. Several Schatten predictions of solar flux are
shown along with the polynomial trend. Notice the Schatten predictions cover
one or two solar cycles.
A study was conducted to determine the approximate performance of these predictions
over the last three solar cycles. (Note if Cycle 20 is included, the results would be different as the polynomial trend does not account for a varying solar
cycle length. Hathaway et al., 1999, indicates that the solar cycle period can vary (by years) from the ‘common’ 11-year
period. Currently, the estimates are uncertain until the solar cycle has about 3 years of observed data. It’s unclear if the most
recent predictions can accurately model this variability.) In each case, the average deviation (average absolute
difference from each value) and the standard deviation (of those differences) were used. 81-
day and monthly averages were examined. Table 3 shows the results for about the last 3 solar
cycles.
Table 3. Estimated Space Weather Accuracy. This table lists several quantities
for the ‘accuracy’ of the space weather values. The 81-day average is compared to
the actual daily values, as well as the trend, and monthly values. Statistics are
formed over the last 3 solar cycles. The monthly trend is perhaps the most
relevant number as it compares directly to the Schatten predictions.
The monthly trend information in Table 3 compares directly with the Schatten
prediction values. Figure 16 shows the average and standard deviations for the trend and
![]() Fig. 16. Schatten Prediction Performance. The average and standard deviations are
shown for several Schatten predictions, along with the polynomial (Trend) for
the same monthly interval. All values use monthly averages of the F10.7 data.
Notice as the number of actual data points in the Schatten predictions increases,
the statistics become worse. However, the statistics are slightly better in the
short term.
The above results were then compared with published information about the uncertainty
of the predictions. From NOAA (http://www.sec.noaa.gov/forecast_verification/F10.html),
the predicted one to three-day uncertainties are about 3-5 SFU at solar min, and 10-25 SFU
near solar maximum (one-day, to three-day values). A few comparisons were also made with
the 45df.txt and predict.txt files. Each exhibited similar variations to those shown in Table 3.
Given the variability and the frequency of updates for the NOAA and Schatten
prediction files, coupled with the extreme sensitivity of propagation results using even very
small differences in the space weather data file (Vallado 2005), it may be more convenient for
some applications to use the simple polynomial trend when decade or longer predictions are
required. As Table 3 and Fig. 16 show, the variability of the polynomial trend is about the
same as the 81-day average data. In addition, the primary feature not modeled in the
polynomial trend is the delay introduced by a longer than average solar cycle (e.g., Cycle 20).
However if a longer cycle occurs for Cycle 24 or Cycle 25, the polynomial trend will predict
an earlier occurrence for the solar maximum. Thus, any satellite designed on this prediction
will have lower than anticipated fuel budgets, in the early portion of the mission, due to the
lower atmospheric drag contribution.
A side note on the performance of the centered 81-day values versus the trailing 81-day
average is warranted. It appears that the centered values ‘slightly’ better model the time-
varying nature of the solar flux data. Many atmospheric models are designed and assume use
of the centered 81-day values. However, operational centers often use the trailing 81-day
average for practical reasons. Perhaps a mix, depending on the time span of interest, would be
better.
Space Weather Data Summary:To assemble a seamless file of space weather data, the following NOAA files should
be used.
AVAILABILITYThe process of assembling these files includes several steps. First, the files need to be
downloaded. The new files can then be assembled. Once accomplished, this entire operation
could be automated to provide the available Internet resources. Dr. Kelso provided the
automation for this task and the results are located at
The space weather data is updated on CelesTrak every three hours at 35 minutes past
the hour (e.g., 0035 UTC, 0335 UTC) since the 3-hourly data seem to come out at 30 minutes
past the hour. A difficult task was determining the data file update frequency, and the
reliability of data being available at the posted times. Most sites were pretty regular, but some are very erratic. The sites listed above will provide nearly real-time updates for both sets of
files. The formats are given at the top of each file and will be consistent for use with the next
release of Analytical Graphics Inc. Satellite Tool Kit (STK). Since the files are simple ASCII
data, they may also be used with other applications.
CONCLUSIONSThis paper has investigated the available data sources for EOP and space weather data. There
are numerous sources of data for each, and arguments are presented for forming seamless data
files for use in operations. The IERS data is recommended for historical EOP values,
reserving the Bulletin A and B for predicted values. Although the NGA coefficients are useful
and included in the datasets, they do not appear to be accurate enough to support operations.
A recommendation is made to use a splining technique to convert between ap and kp values.
The ability to replicate the discrete values and the closure properties are cited as supporting
rationale for this choice. A polynomial trend is presented and recommended for the formation
of long-term solar flux values. Several statistics show it is very similar to the Schatten
predictions that are published intermittently. The agreement over the last several solar cycles
is very good, suggesting this could be an alternative for users wishing long term space
weather predictions. The process has been automated by Dr. Kelso of AGI’s CSSI group and
the data files for both are available at http://celestrak.com/SpaceData/.
Ðàçìåùåí 9 äåêàáðÿ 2006.
