NEW WIDE FIELD CAMERA FOR SEARCH FOR FAST OPTICAL TRANSIENTSA. Pozanenko1, S. Bondar’2, E. Ivanov2, E. Katkova2, G. Beskin3, S. Karpov3, A. Biryukov4, I. Zolotukhin4, K. Hurley51 IKI RAS, Moscow, Russia 2 Kosmoten Observatory, Karachai-Cherkessia, Russia 3 SAO RAS, Karachai-Cherkessia, Russia 4 SAI MSU, Moscow, Russia 5 UC Berkeley Space Sciences Laboratory, Berkeley, CA
Even though Gamma-Ray Bursts (GRB) were discovered in gamma-rays, they are now truly
all waveband events: the emission has been detected from radio up to high energies (GeV).
However, GRB identifications start with γ-rays (i.e. omni-directional γ-ray detectors report
them first), and practically nothing is known about the prompt emission in other wavebands.
Discovering and investigating this prompt emission may give clues to the physics of the GRB
central engine. The mystery of the optical prompt emission seemed to be ready for resolution
after the observation of GRB990123 [1]. However, in the 5 years following this discovery no
synchronous emission (during the GRB onset) and only a few cases of the prompt one (during
the active phase of GRB in γ-rays) have been observed: GRB990123 (= 8m.9), GRB030329
(upper limit > 5m.1), GRB040825 (> 10m), GRB041016 (> 13m.1), GRB041219 (= 19m.4),
GRB050215b (> 10m), GRB050309 (> 3m.8), and GRB050401 (= 16m.8). The problem is that
the astronomical telescopes and the observation methods when using them are not fully suited
to the problem.
To register the prompt emission we need to look for celestial optical transients (OT)
independent of the alert system. Although the time delay between a GRB trigger and an
optical observation has been drastically reduced with the new generation of space observatories (HETE-2 and Swift), it will never vanish completely. Hence, an alert-based
observation cannot register either an early prompt emission, or possible optical precursors, or
afterglow, or the prompt emission from short duration bursts [2]. In any case the early
observations are the most likely way to find optical counterparts.
To ensure that an OT is a counterpart to a GRB one needs to confirm the event in γ-rays.
Simultaneous observations with space-borne GRB missions are therefore needed. It is not
necessary, however, to correlate the optical and γ-ray data in real time; we need only assure
that both telescopes observe the same field of view of the sky simultaneously. The joint
correlation analysis may be done later. Observation of only a specific part of the sky
decreases the amount of data to be stored in comparison with all sky surveys [3, 4], and
allows the time resolution of the survey to be improved.
The FOVs of the telescopes and the time resolutions of the detectors are crucial points
in the search strategy. Astronomical telescopes have smaller FOVs compared to space-borne
X-and γ-ray telescopes (e.g., the Burst Alert Telescope (BAT) of the Swift mission has FOV
of 1.7 steradians). Specialized telescopes may have a wide FOV (19.5 x 19.5 degrees with 30
s time resolution, such as RAPTOR [5]), but do not possess a sufficient sensitivity with the
appropriate time resolution or vice versa (1.85 x 1.85 at 4 s, ROTSE-III [6]). To detect the
prompt emission efficiently the time resolution should be better than, or nearly equal to, the
duration of the event. If the prompt emission consists of short duration optical flashes (e.g.,
[7]), then a high time resolution detector should be used. Moreover, if the nature of the
prompt optical emission is similar to that of the γ-ray emission, a fast variability may be
expected down to the millisecond range.
Obviously, the larger the FOV of the telescope, the larger fraction of the GRB error-box
can be observed simultaneously, and a more sensitive detector has a greater chance of
detecting a faint OT from a GRB. On the other hand, in a simple case of a fixed detector size
(e.g., a CCD-matrix), increasing the FOV decreases its sensitivity. (More sophisticated cases
are discussed elsewhere [4]). One can show that the number of detected GRB optical events
per a fixed accumulation (exposure) time and a fixed size of the detector may be expressed by
the formula
NDetected ~ (D/α)3/2 * FOV,
where D is the telescope aperture, α the angular resolution, and the FOV is expressed in steradians; here we assume the 3-D Euclidian space and a uniform distribution of GRB
sources N (> S) ~ S-3/2. One can see that the telescope with the larger FOV can detect more OTs, and the OT detection probability can be maximized while observing simultaneously
with a given space-borne telescope.
In view of this strategy we have developed a low cost optical camera for a wide field
survey and an autonomous search for OTs [8]. We use an image intensifier both to reduce the
size of the image in the main objective lens focal plane to the small size of the TV-class CCD
matrix, and also to amplify the light to compensate for the light lost in transmission through
the optical system. The details of the camera are the following. The main objective lens (15
cm diameter, F/1.2) of the camera projects the 17x20 degree area onto an image intensifier
photocathode of 90 mm in diameter (the quantum efficiency is 10%, the gain is 150, the
scaling factor is 0.22). A special optical system transfers the image from the intensifier to the
VS-CTT285-2001 TV-CCD camera (1280x1024 pixels with the size of 6.5 microns each) at
the frame frequency of 7.5 Hz (the exposure time of 0.13 s).
The practical parameters of the instrument are the 17 x 20 degreesFOV with the spatial
resolution of ~1’ and the limiting magnitude (the 3σ-level) of 11m.5 for the 0.13 s exposure time. The limiting magnitude of 13m is reached for a 13 s exposure (stacked in the PC
memory). The spectral sensitivity is close to V. The instrument is mounted on an appropriate
equatorial mount with the pointing and tracking accuracy of a few arc minutes and better than
1’ in 2 hours, respectively.
The relatively poor spatial resolution is the result of a compromise between the cost of
an instrument and its wide field of view. Indeed, a precise spatial resolution in fast
observations of stationary astrophysical objects is less important than the early detection: the
precise localization can be done later by more sensitive large aperture telescopes provided the
coordinates will be promptly transmitted and a robotic large aperture telescope immediately
slews [9]. Because of the high readout noise of the TV-CCD, the sensitivity of the camera is
restricted by the noise at minimum exposure time, and by the sky background at maximum
exposures.
In order to process the 13 Mb per second real time data stream coming from the camera
a special software suited for the data storage, detection, and investigation of OTs has been
created.
The software is installed on three PCs running the Windows (the frame grabber and data
storage) and the LINUX (real-time data analysis) operating systems. One additional PC is
used for the automatic pointing control. The incoming information is a sample of 1280 x 1024
pixel CCD frames with an exposure time of 0.13 s. The low-level software performs the
following tasks: the real time data transfer to the LAN; the accumulation of raw data (up to
0.5 Tb per night) at the RAID. The data reduction in real-time, i.e. the detection of OTs,
determination of their equatorial coordinates and stellar magnitudes, and identification of the
OTs with known objects; distribution of information about newly discovered OTs to the local
and global networks (the alerts distribution) are produced by the high-level software.
The real-time OT detection algorithm is based on the comparison of a current frame
with a reference frame, being the frame averaged over 10-100 preceding ones, and consists of
the following steps: extraction from the current frame of all pixels with intensity deviating
from the reference frame by a given fraction of the RMS noise; location of continuous regions
of such pixels on the current frame and determination of their parameters, i.e. coordinates and
fluxes. All these regions are considered to be optical transients (OTs), if they exist on at least
3 successive frames. The shortest optical transient which can be detected automatically has a
duration of ~0.4 s. The next steps of the algorithm include the analysis of the OT’s shape (on
a single frame) and the proper motion of the region center; classification of OTs as meteors,
satellites, or stationary transients, and parameter estimation (the trajectory, light curve, etc.);
for the two last cases – for comparison of the object parameters with those of the known
objects taken from star and satellite catalogues (it should be noted, however, that the
available satellite catalogues are not complete); for stationary transients with no known
(catalogued) events, the information about their parameters can be sent locally and into the
alert distribution networks (such as the GRB Coordinate Distribution Network [10]).
The high time resolution raw frames are stored in a data base for a limited time (usually
2 days), and within the 2 days can be used for detailed analysis. The long term data base
consists of stacked images (of 100 original frames of ~13 s exposure time) and may be used
for the search/analysis of long term variable sources. Every raw data set for a night is also
transformed into a ~3 minute film for a visual post check of observation parameters, and the
film is stored in the long term data base, too. Finally, for an event identified as an optical
transient (of any nature), the equatorial coordinates, brightness, and UT are stored in a long
term data base and can be used for the correlation analysis, together with the data related to
different wavelengths. In the case of an event having been classified as a non-stationary one,
the coordinates can be used for the trajectory determination. The accuracies of the automated calculation of coordinates and of the reference time are acceptable for calculation of the
accurate orbit elements of low-orbiting satellites [11].
The camera has been operated in the test mode since the end of May 2003. During the
operation periods up to October, 2005 the total number of good nights, i.e. during which the
WFOC observed the part of HETE2 WXM FOV, is 257. The average number of meteors
brighter than 9m is between 8 and 20 per hour. No synchronous GRB observation by use of the
HETE-2 was recorded, which, compared with the HETE-2 GRB rate in 2004/2005, is well
within statistical expectations. Most autonomously generated alerts were due to active
spacecraft and space debris. The average number of moving objects associated with satellites
is about 300 per night. A few objects per night are still non-classified, i.e. no correlation has
been found either with satellite catalogues or with gamma-ray/X-ray triggers. Examples of the
non-classified events are available on the website (http://rokos.sao.ru/favor/selected.html).
More statistics (or confirmation by other telescopes) is needed, however, to establish the
astrophysical nature of such types of events. The events should be, henceforth, considered as
artificial ones generated from non-catalogued space debris.
The primary purpose of this WFOC is to perform continuous, alert-independent
observations of optical transients and variable astrophysical sources simultaneously with
space-borne X-and γ-ray telescopes. This fully autonomous camera can detect and perform an
early photometry of the prompt optical emission from both the long and the short duration
GRBs, optical flashes preceding the gamma-ray emission in the GRBs, GRB afterglows not
identified in γ-rays (orphan afterglows), optical outbursts related to the Soft Gamma
Repeaters, and possible fast optical supernova precursors. Large FOV and fine time resolution
make it possible to search for non-catalogued space debris and calculate the orbital elements
as a by-product, while the camera is hunting after astrophysical objects.
Acknowledgments. This work was supported by US Civilian Research and Development Fund (RP1-2394-MO-02).
Ðàçìåùåí 7 äåêàáðÿ 2006.
